TAB electrical outlets
xheavy
Member Posts: 10
Does anyone know where to purchase to the electrical outlets like under the dining table on a Tab 400? Already emailed Nucamp just wanted to see if anyone knows where to get them.
Thanks
Thanks
2018 Tab 400 / TV 2017 GMC Canyon Diesel
@xheavy, I'm sure they are available from nüCamp. Good luck.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
If they are the kind with the push in wire retainers, I got one at Amazon.
https://www.amazon.com/RV-Designer-S811-Contained-Outlet/dp/B008OJ6XA0/ref=sr_1_1?ie=UTF8&qid=1536716205&sr=8-1&keywords=RV+Designer+S811
2014 T@b S Max AKA T@dpole -
You might see my recent post T@b 400 Power Center Addition. I included a few nuCamp part numbers and info about the manufacturer. I hope it helps you out.
Thx
BillyThe T@b Mahal
T@B 400 2018 | Ford V8 2014 | Rio del Mar, California
Are you just looking to swap out the receptacle itself? If so, they are just standard 120V fixtures. Your nearest hardware store should have plenty.
Thanks everyone ordered what I needed from Nucamp. Whitney is a lot of help.2018 Tab 400 / TV 2017 GMC Canyon Diesel
I know a bit late for OP but I ordered some 120V outputs with two USB charge ports built in. I plan to install on the 120V side on our Tab by bed so we will have USB ports on both sides when we have AC hookups.
the ones I got are UL listed so should be safe.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
