tab 320 s max
what is differences between 320 s and 320 s max the one iam looking at is a 2014 320 s max
    The  Pleasant Valley factory teardrops were previously marketed as CS (clamshell) or S (Shower) Basic through Max with the Max loaded with A/C, wet bath, etc.  Now, the 320s is the inside kitchen model with A/C, wet bath, front window as standard.  So basically the 2014 model you are looking at has the wet bath.  Different versions of that year may have surge brakes as opposed to electric brakes as well.  It may not have the front window and may have the old style table.
    This is from a previous post re model years.  2014 does not have the outside 110 outlets, either.
    You will want to make sure the S model has a Norcold vent fan to exhaust the heat from the frig - that was second half of 2015 - early 2016's I think.  Upgraded cushions with the 2016 models, late 2016/2017 with shades that pull up and screens that pull down ( earlier models were reversed and had shade sag problems), electric brakes late 2014 addition?, Lagun table and bed slats standard starting late 2016/early 2017.  When did they add the pull out steps?
    From a thread - changes for 2016:
    • 3D Logos
    • 100% Azdel Backers
    • Radial Tires (2015)
    • 30 amp power cord w/ built in LED light (2015)
    • Fantastic Fans will be clamp on which makes them screw free
    • Corrugated underbelly protectant & insulation
    • No fabric on window valances (they will be like the Outback)
    • Seat Panel Finger Inserts for Finished Look & EZ Opening
    • Upgraded upholstery foam density
    Late 2016 -added Digital Alde display
    And another thread:   They have made standard in 2017:  included bed slats with a cleat to secure the slats, Lagun table, shades that pull up rather than pull down, screens that pull down rather than pull up, struts to support the cabinet doors, different faucet in the galley sink.
    2018 model changes:
    Different upholstery
    CS models with standard front counter and cabinets and 3 way frig
    Standard front window and outside shower
    New Norcold 3 way with side venting
    I think a change in the overhead fan???
    Hope this helps.  Hang around - 2020 they are going for the self-propelled model!  Always improving.
    Can't wait!
    (snip)
    ...........Hope this helps.  Hang around - 2020 they are going for the self-propelled model!  Always improving.
    edited October 2018
    This site shows the difference between Basic, QuickStart, and Max set of options...  at least for the 2015 line-up.
    http://www.tabownersclub.com/tab-camper-info/
    "Max" includes 3 way fridge, wall A/C, 19" TV that are options in non-Max T@Bs.  Not sure if those were the same options vs. standard for 2014 as well.
