Propane Hose bracket behind tub dropped from trailer wall.
I was cleaning my trailer after a recent trip, and discovered the bracket that holds the propane hoses from the tank toward the inside of the Tab separated from the wall behind the tub.  It was hanging by one loose screw, and I pulled it away from the wall (tank is closed!)
The holder is attached to the trailer with two screws, one which is now missing.  There is a soft gasket-like material on both surfaces that I assume helps keep water out.
Here is the remaining screw.  I am hardware-knowledge limited, but I guess this is a self tapping screw, and the debris is the foam inside the Tab's walls.
Are those correct guesses?  So, I need to know what the gasket material might be, and the size of the screw.  And, by replacing the gasket and the screws, should those fixes hold the regulator and hoses up?  Or, worse case, is there a bracket behind the diamond plate that needs to be fixed?
  • ChrisandAlexisChrisandAlexis Member Posts: 120
    I am interested in the answers too as I just installed dual 6 volt golf cart batteries and had to take off the propane regulator bracket to get the batteries in. Now I have to remount the bracket somewhere else.
    Chris and Alexis-- Roseville, California--2017 T@B CS-S--Toyota 4Runner
  • MuttonChopsMuttonChops Member Posts: 1,751
    I recently had to remove/mount the Battery Cut-Off Switch and it used the same screw as you have pictured.  My guess on what's what is the same as yours.
    For the Battery Switch, I just used some white caulking to reseal.
    Adventures:  55   Nights:  376  Towing Miles 46,920
  • MarcelineMarceline Member Posts: 1,625
    I recently relocated mine. Yes, they are self-tapping Robertson head screws. AFAIK there is no backing plate.
    I reattached mine with two fresh screws and 3M 4200 adhesive/sealant. I also used the 4200 to fill the existing holes. That's a bit of overkill, but I had a tube of it open so that's what I used.
  • pthomas745pthomas745 Moderator Posts: 4,095
    @Marceline thanks for your help!
    So, did this set of screws just work themselves loose like the other screws in the trailer do?
  • Tabaz Tabaz Member Posts: 2,377
    Happened to me too. Used slightly larger screws and adhesive. Has held for several months.
    No. I had to move mine because I got a different propane cover. I have a 2013 CS and the screws were still attached when I took them out.
