Where is the Alde Expansion Tank located? I'm getting into the
installation and plumbing of the Alde in my 2017 T@B and can't locate
the expansion tank (Figures 2 and 7 of the manual). I would have thought
it would have been near the boiler/HW tank but I can't seem to locate
it.
Thanks
0 ·
Thanks
Sorry but I'm just not finding it. Do you suppose anything changed between 2016 and 2017. We picked up the trailer from the factory on 5/17.
When I checked the fluid level it was at the Max line when cold. The manual says it should be about 1/2" above the Min line when cold. The service department where I bought the RV at says that is OK because if it does overflow, it will go thru the overflow tube to the outside.
Does that sound right?
Adventures: 55 Nights: 376 Towing Miles 46,920
Followup would be, how do you gain access to what's under the headboard shelf?
Thanks
2016 T@b Q
Lakeville, MN
Its next to the headboard shelf on the drivers side and held with two screws
Replace the shelf when done, and replace the screw(s).
I'll take a look at the screws holding the headboard shelf on, and see what I find.
Thanks
2016 T@b Q
Lakeville, MN
