Can anyone tell me what this connection is for inside the battery/propane box on 2009 DM? I'm thinking maybe some sort of fuse for the battery and that it would be a good idea to know how to replace it if it blows:
Also, does anyone know what the amp draw of the T@B is when plugged into shore power and just charging the battery? I want to keep the battery charged when storing the trailer and I'm thinking of just plugging it into an outlet in my garage. But don't want to trip the breaker on a 15amp circuit if the battery charger is going to draw more than that. I can run a 30amp circuit out to the garage but don't want to if I don't have to. I might also get a solar trickle charger but again, much easier to just plug it into existing garage outlet if that would work.
Thanks!
Ben
The maintenance current is 1/2 to 2A or so, at 12v, which translates to around a tenth of that at 120v.
Even at an initial high draw, it wouldn't be more than around 3A or so at 120v.
Durango, CO
I would consider using a battery tender to maintain the trailer battery when it is sitting idle at your home. In as much as the trailer's electric converter will maintain and float the charge, I would not plug that in for any extended/idle duration, in an effort to save wear and tear on that device. A tender is cheaper and would be much easier to replace should it ever go bad.
And agree with the comments above, that device is either a wire terminal block or some type of circuit breaker in the event there is too much load or resistance on the circuit. You know the old saying, "it's best to let a sleeping dog lie."
"A replacement fuse in the hand is worth 2 at the auto parts store 50 miles away"
Solar Charge Station
