Tire mount on boondock edge
Robnrina
Member Posts: 39
I am looking for where to purchase a tire mount like this. I have looked online at teardrop.shop as the dealer recommended, but no luck. I am not sure what it is called. We just got ou new 2019 320 s that has the front metal platform like a boondock edge, and hope to add the tire holder....depending on the cost!
2019 320 s T@b white/ black
2008 Honda Ridgeline
Believe that tire mount is nüCamp custom. You can most likely order directly from nüCamp.You'll find less expensive tongue mount methods by searching this forum. Many of us use a simple bolt-on trailer spare mount attached to the Jack Post.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,1801 -
Thank you!2019 320 s T@b white/ black
2008 Honda Ridgeline0 -
Towed by 2014 Touareg TDi1 -
I've also got a feeling that you would have to remove your entire standard boondock platform, and then install the edge platform. They are a one piece welded item.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL1
- 956 Air Conditioning & Refrigeration
- 921 Introductions
- 75 Teardrop Groups & Links
- 918 Tips & Tricks
