I have a 2015 T@B CS-S Max which has had very little use due to hubby’s health issues. He passed over the summer and I’m debating over what to get for a new tow vehicle trading in my 2016 GMC Sierra 1500 double cab, which is WAY more than I need and is also an Ark to Park. I’m a former Subaru owner and am leaning in that direction but am concerned about what others think about mileage, overheating, things that might need to be added to the vehicle, etc. Also would appreciate input on the GMC SUV models and what their pos/neg views are. I am not planning on doing anything until spring and depending on whether I go back to work (currently retired) or not will also affect how much traveling I will do. Sorry this is so long. Thanks in advance.
0 ·
You might check out the Subaru Ascent. It’s a 3 row SUV, but you can remove the last 2 rows for more cargo area and has a towing capacity of 5000 lbs.i know we’re looking at it for our next tv. There’re a couple of Ascent owners on the forum who might pop up with real life info.
Dallas, TX
'19 T@B 400 Boondock Lite/Jeep Grand Cherokee Trailhawk
Current Terrain is a bit smaller and has several 4 cyl engines to choose from. The most powerful is turbocharged, and can tow up to 3500 lbs I recall. (Don't think a diesel is available.)
For comparison we did have a turbocharged 2007 SAAB and towed a popup tent trailer with it, almost as heavy as a T@B, and the turbo 4 cyl had plenty of power. Only issue was too much tongue weight thus rear of SAAB seemed to sit too low...ride designed to be plush, not for towing.
In my opinion a naturally aspirated 4 cyl will be struggling some of time, while a turbocharged 4 cyl might be fine all of the time. If anyone is towing with new version of Terrain I'd like to hear what they have to report. I presume Chevy has a version also.
Good luck.
Good luck on choosing your next TV.
The videos on the Ascent are impressive when you see the anti-sway control in action.
2015 T@B M@X S White with Grey trim | TV 2021 Ascent Touring | Flagstaff AZ.
2022 Ford F350 Tremor | 2022 Cirrus 620
