Finally spring has sprung up here in the north country and I have de-winterized my new T@B, which is a 2015 S M@x.   Everything seems to be in working order with the heating system but I do have a couple of questions for those of you who are familiar with the 2015 Alde configuration.   There is a valve on a short line between the hot and cold water lines.   Right now it is closed.    What is that valve for and should it remain closed during summer camping season?
Also, what is the yellow valve for, which is on a cold water line, just before it enters the Alde unit?   It is different than the other gray valves.    Right now it is in the down position.   What does opening it up do?   How should this valve be positioned for normal operations?
I realize that there have been slight changes to this heating system over the last few years but I'm hoping someone can shed light on these issues for me.
0 ·
Do a search for winterizing the Alde, either here or in the Yahoo group.
The short line between hot and cold is the by- pass, for draining and adding antifreeze in the lines but bypassing the boiler. Keep this valve closed during hot water operation.
J.D. & Sue
