I was re-watching a TAB 400 production line video and see that the black tank is located directly under the toilet and above the floor. However, I cannot determine where the fresh water tank or the gray tank is located. Does anyone know? Are they mounted under the floor between the frame rails? I don't see that they could be mounted above the floor anywhere. It seems logical that the fresh tank might be mounted transversely aft of the axle between the frame rails just below the fresh water fill port. The gray tank would probably be transversely mounted just forward of that next to the gray tank dump valve. Does anyone know for sure?
On a related note, the factory brochure states the base tongue weight is 390 lbs and the "wet" tongue weight is 400 lbs. What does the "wet" weight entail? Is it just a full fresh water tank or does it mean full fresh, black, and gray tanks? or something else entirely? I expect the wet weight would also include a full propane tank.
0 ·
Yes, black water tank is 'above the floor'.
Yes, fresh and grey tanks are 'below the floor'
This picture (chassis upside down during tank mounting) shows the Grey Tank {under red tool caddy} and the white Fresh Tank waiting to be installed.
https://tab-rv.vanillacommunity.com/discussion/comment/92705#Comment_92705
Comparing different NüCamp data sources found this:
I don't think "wet weight" includes water in tanks...
I had the impression it was only the 'more permanent' items like the battery and the full propane tank.
I think it's unusual to travel with full black, grey, or fresh tanks, so I doubt they would be included in that spec.
The fresh tank, since it is very near the axle probably affects tongue weight very little. The gray tank being farther forward would have a greater effect but it is smaller. The black tank, even farther forward, would have the greatest effect, but it is smaller than the gray tank.
