Was just looking at a new unit and noticed for the first time what looks to be very limited clearance between the tire and the plastic trim on the outer edge of the wheel well. It doesn't appear to me that more than an inch or so of body travel is possible without making contact with the tire.
Anybody with a 400 Boondock had any issues with the tire rubbing the wheel well trim?
0 ·
The non-Boondock tire is 205x75/15. I bought my 400 with the steel tub and the pitched axle but I passed on the Boondock tires. I probably should have gone with the complete Boondock Lite package since that would have added another 1.77" to the overall height of the trailer and my purpose with the pitched axle was to get a little more ground clearance for traversing a steep driveway apron. I passed on the Boondock tires because I don't think there is much utility in an aggressive tread pattern on a non-driven wheel.
BTW my 400 (with the 205 size tires) has about 3" clearance front and back and 4.25" on the top.
At this point I am leaning toward changing the order to non Boondock and having them ship it with the aluminum tub. I think it would be real hard to drag the tail end going over rough or steep terrain, the real vulnerability is the sewer drain, that needs a skid plate or some such Boondock package or not.
While considering the tires, note that I made an informational post to any Boondock Lite owners regarding the availability of the tires should there be an issue on the road. Look-up "2019 T@B Boondock Tires: Rainier Apex ST235/R75" or click https://tab-rv.vanillacommunity.com/discussion/8151/2019-t-b-boondock-tires-rainier-apex-st235-r75#latest
In researching the tires I realized I had no idea what kind of axle was actually on the Boondock. Supposedly it's made by Dexter but when I went to get details on it to see if it's a Never-Lube bearing, I realized that any info tickers must be covered-up by the plastic cover. I'd take off the wheel to look closer but as there is no publicized information for where or how to place a jack, nor any obvious place to do so, I'm stuck there too.
In short, while I have a Boondock Lite and I ordered it because of the ground clearance, it seems that part comes from the tire and part from the axle. I did so because the axle is supposed to be stronger and even 1.25" is a help. As to the tires rubbing the ABS, its pretty flexible and soft but just don't see them articulating that way. If they do at any point, we can cut them back a smidge but it doesn't seem to be an issue.
In good time, this will all get sorted out.
Tire Size Calculator
https://www.tacomaworld.com/tirecalc?tires=205-75r15-235-75r15
So it appears to me that at least on the 400's about the extra 3" of clearance can be contributed roughly equally to the axle and tire? I am not as worried about the fresh water drain as I am the dump valves, in part because going through a ditch, etc. the fresh water drain is closer to the axle and will rise as the tire walks over a ditch, curb, etc. Of course a tall rock, stump, etc. the tire misses could peel that right off! The sewer drains OTOH dip down as your tow vehicle crosses the ditch or a driveway curb cut for instance and stand a real chance of dragging.
The axles are indeed a Dexter easy lube variant and are nothing specific to NuCamp products as far as technology and design, they may be built to NuCamp specs as far as mounting, length and rise, etc. There are really about two companies that make ALL trailer axles, Dexter being one. I have a similar Dexter 3500 pound axle on a Wells Cargo that has been excellent for 30K miles. AFAIK the "stronger" axle may apply to the 320's or it may be marketing fluff, when you look at axle ratings between the regular and Boondock 400's, I don't think you will find a difference?
As far as jacking, I have jacked my WC on the frame and I suspect that is the best course of action on the Tab's also. Having said that, I bet a tire store is going to put a floor jack under each side of the axle and jack away. I looked in a few other brands forums and guess what? Trailer tire changing is a topic there just like here with no definitive answer except the axle manufacture says don't jack on the axle, LOL. I was also looking at something like this jack: https://www.amazon.com/SeaSense-Tons-Easy-Lift-Trailer/dp/B000FZ345S but of course that jacks on the axle and apparently must sell or it wouldn't be multiple places on the internet...
As for the trailer tires, while I'm concerned about having to replace them due to a sidewall issue, the reality is that you rarely need to do so. Moreover, a simple fix is to replace the spare 205 tire with a new 235 tire and call it a day. That's probably the route I'm going to take once I get a definitive answer, in writing, from nuCAMP on where and how to jack so I don't void the frame or axle warranty. It's just an oversight on their part which should get sorted out once they come back to the office. These Boondocks are new so the questions will bounce around till the right person sees them.
My worst case would be to replace both tires with a Goodyear or equal 225 should we be somewhere remote and can't figure out the 235. The focus on knowing what we have, and where to replace parts, is to eliminate the frustration and time waste when in the field with no WiFi on a Holiday weekend Saturday afternoon in the rain.
I bought a 400 off of the floor without the Boondock package. Intent is to change the axle and upgrade the tires. There aren't a lot of trailer tires in 235, but there are a ton in 225. That said, there are many, many tires available in a 235. I'm sure some would be plenty good for a light trailer. If you want the Boondock look, the Goodyear Wrangler Duratrac looks similar. If you were to get stuck with a flat, you'd probably have better luck finding a 235 LT tire on the road than a 225 ST tire. My TV is pretty big, so I'm debating just buying a set of 4 tires and wheels and keeping one on the trailer and one in the TV.
In comparing my Boondock Lite to the standard 2019 T@B 320 S models I saw at the dealer lot, I would say that the additional ground clearance is closer to the 3" additional clearance you have discussed. Mine is definitely more than 1" higher, but the 400 and 320 S may be slightly different in clearance.
