TAB 400 Tailights
Has anyone had an opportunity to remove a taillight (the STT lights) on a TAB 400?  How does the silver trim ring come off?  I suspect there are plastic clips holding it on but how many are there and where are they?
    I would call Austin Jones down at the NC repair shop as he will be able to help you out.  I’m guessing that the tail light assembly is a sealed unit and will require some work to get it out.  I would consult with Austin and am sure he can give you the best approach in removing the unit without damaging your trailer trim, the fixture, etc.
