Hi. I just ordered a progressive industries surge protector that has the remote display. I have seen some of your posts about the display placement, but are you all happy where you put it or would you move it? I ask because after putting in my battery monitor I kind of wished I had taped it in place to see if that’s where I really wanted it. Not moving it because I already drilled a hole. Anyway, thanks in advance and happy t@bbing!
0 ·
I feel I have more need to see it as I plugging into electrical service. If there is an “event” during the time I am plugged in, it will take care of the electrical service and I would need to go outside to the plugin anyway if some “event” happened.
So I guess that is where they are putting mine.......
WilliamA
2017 T@G XL
The wiring and monitor are attached only with zip ties.
The EMS is mounted in the drivers side compartment adjacent to the power converter and the shore power on our 2018 T@B 320 S. The incoming shore power cable was cut appropriately and rerouted through the EMS.
And the monitor wire is run up the shower wall to the TV mount.
The monitor wire was tucked inside the plastic wire loom to the TV support arm and wire tied on.
TY
Considering a 2023 TaB 400 with the full Lithium option,
2022 Jeep Gladiator High Altitude, Tow Package.
