Android phone Profile and Signature Access
System
System Administrator Posts: 192
This discussion was created from comments split from: 2018 320 CS-S.
  • BrianZ
    BrianZ Member Posts: 1,770
    @Sharon_is_SAM, how does one create or update his or her signature?  I can't find an option for that.  I've looked under "Edit Profile", but only saw the Activity box, which I understand is not for that but a public bulletin board.  I use the Chrome browser on Android, so can change to "Desktop site" in browser settings, but this doesn't seem to help.  Maybe only a PC, or have I overlooked something?
    I'll check.  I have Apple, so we'll see.
    @BrianZ,  I received this info from @dragonsdofly back in August.  This is what she does on her Android phone.  Make sure you are using the vanilla address and not accessing the forum from the nuCamp website.  Let me know if this works for you.
    Sharon
    Android Phone
    1.  Sign in at the Home page:   https://tab-rv.vanillacommunity.com/
    2.  Locate the three dot additional info menu at the top right hand side.
    3.  Select "Desktop View" from the menu.  Horizontal is easier to read.
    4.  Tap the “gear” icon in the upper right corner.
    5.  Select “Edit Profile”.
    Your full-view Edit Profile menu appears on the left.
    Signature Settings second from the bottom of the menu list.
  • BrianZ
    edited January 2019
    Must have been step 1, because I've been using the NüCamp site.
    Thank you both, @Sharon_is_SAM & @dragonsdofly .
    @BrianZ, so it worked?!
  • BrianZ
    @Sharon_is_SAM, yes, at least it appears so to me, but since you're asking I wonder now if it did.
    I guess you didn’t have a signature before, so it worked!  Haha!
  • BrianZ
    Correct, @Sharon_is_SAM, I had to use the vanilla site to get the signature menu to create it.  And now that I've made one, I can see it on the NüCamp forum by selecting "Desktop site" from the Chrome browser's setup menu.
    @BrianZ, so are you saying that you can not see it from your phone using the Vanilla web address?  Do you always use the forum access via the nuCamp website link?
  • BrianZ
    No, @Sharon_is_SAM, not saying that.  I can see signatures in forum posts at either site, but when using my phone browser only if I select the browser setting "Desktop site" so that all web site features are displayed.  Otherwise, I won't be able to see signatures at either site.  Additionally, even with the "Destop site" setting selected in the Chrome browser, I can only get the signature menu item for creating/editing a signature by using the Vanilla forum;  cannot see it at the NüCamp site, no matter what settings I use.
    Yes, I generally only use the NüCamp site, usually from a bookmarked link, probably from habit because that's where I first discovered it & saved that address.  Also know I can get here from nucamprv.com if needed.
    Thanks @BrianZ.
