There are two drains, one for gray water and one for black water. If I'm in a park for a month with full sewer hookup and the black tank is hooked up to the sewer, what happens to the gray water? Do I have to intermittently go out and disconnect the black tank and connect the gray tank? Is there a Y fitting I can buy that will connect the two drains into one line? I'd like the black water and gray water to go down the tubes together.
2017 Tab 320 S
2014 Mazda CX 5
Traveling very light to be kind to my transmission.
0 ·
Alan & Patty
Southern Az
2014 Mazda CX 5
Alan & Patty
Southern Az
As noted, when in a park you keep the black valve closed and only dump when the tank is nearing full as this helps move material and you dont want waste or paper drying inside the holding tank. Gray water is different but also helps clean the hose after the black tank is emptied.
Here is a helpful FAQ on homding tanks.
https://www.coltonrv.com/rv-gray-water-black-water-faqs/
2014 Mazda CX 5
2014 Mazda CX 5
1. You can fill the tank by flushing, using your shower wand, or buckets of water and then drain. Some folks may suggest driving around with an almost full tank to loosen things up a bit, then drain.
2. Use a device for back-flushing your tank. Search “Tank flush” here on tge forum fir various discussions.
3. Camco has a wand that you can hook up to a hose or maybe even screw it onto the end of your shower hose. You stick the wand end down the toilet (flush valve must be held open) and rinse away. As our tanks are very shallow, I am not certain of the effectiveness of this approach.
Because of the sleeping area proximity to the bathroom, you really want to keep your tanks clean and your valves closed. Make good use of tank additives (Happy Camper for odor and Calgon to prevent sticking debris). Be careful what you put down your gray tank to prevent odors - we use tubs to do dishes and discard the gray water in gray water dumps where available). Paper plates help, too. Also, keep your P-traps from drying out. Water in your shower trap will prevent tank odors from wafting up into the TaB.
Sold 2023 Tab 400
Sold 2018 T@B 320S
