Taillight removal for water leak 2017 320S
Istokpoga
Member Posts: 22
We recently found evidence of water intrusion inside the rear starboard (grass) side corner Seeing other posts regarding this issue I decided to pull the taillight assembly off this side for an initial look.
There are four larger screws on the assembly panel, five smaller ones on the adjoining side panel, and four under/around the grab bar which appear to hold the two trim pieces together. I removed all of these. At this point the rear trim/light assembly will wiggle around but not pull free. It appears "stuck" to the trailer body directly under the reflector.
Question: Is the reflector assembly hiding another fastener, or is this a result of a big blob of silicone adhering the back of the assembly to the trailer body? If it's the latter, I can slide a plastic putty knife in there to break the pieces free from one another, but there's not enough of a gap for me to see in there. The last thing I want to do is break a piece of teal trim "fixing" what is likely a simple issue.
Also, please let me know if this picture is not re-sized correctly. I downloaded an image re-sizer and "think" it's right. Note the quote marks around "think".
Thanks in advance for advice and comments!
Fred
Fred
Fred & Victoria with Bichons Venus & Gator; On the shores of Lake Istokpoga, Florida; Tan@Bell@ 2017 Teal & White 320 S towed by a 2004 Nissan Titan and occasionally by GatorRoo, a 2011 Subaru Outback 3.6 L
"It's great to be a Florida Gator!"
Or just try some Captain Tully’s Leak Fix and don’t mess with it.F150 Pulling 2019 T@B400 BDL
The silicone is holding the tail light in place. Remove it and the tail light comes out. The is very little slack in the wiring. Clean the old silicone out and reapply with liberal amounts of continuous beads of silicone.Verna, Columbus, IN
Verna, that is what I was hoping to hear. A plastic putty knife slipped in there should do the trick. A fair amount of dry crumbly silicone came out with the four larger screws and I am hoping this will resolve the issue.
Thank you!Fred & Victoria with Bichons Venus & Gator; On the shores of Lake Istokpoga, Florida; Tan@Bell@ 2017 Teal & White 320 S towed by a 2004 Nissan Titan and occasionally by GatorRoo, a 2011 Subaru Outback 3.6 L
"It's great to be a Florida Gator!" -
@Istokpoga, your sizer reduced your picture to a perfect 800 x 600. Thank you.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Hi I know this may be an old issue but it my current issue. Arizona monsoons well they’re monsoons and I am having water issues as explained above. I have sealed it with 3M marine adhesive sealant fast cure 4200.Do I need to seal the entire area? I’m learning as I go.
@HowlinWIndWalkr Rather then remove all the light I did the same thing 2 years ago and so far no leak! Art2019 TaB 320 S Boondock Edge
- 919 Introductions
- 407 Service/Maintenance & Recall Notices
- 74 Teardrop Groups & Links
