Folks,
I need to tow with my tailgate attached and down. We went to an RV dealer and I backed up to a T@B 400 and discovered that the tailgate would interfere with the tongue jack but clear the propane tub fine. They said they could fit a side mount swivel jack. Like this:
http://https//www.amazon.com/dp/B000DCN8G8/ref=psdc_3147821011_t1_B000CQOIVO My question is: Does anybody have experience with replacing the jack with a swivel model? Pros or cons?
TIA
Jeff
Jeff & Amy
Now in Manistee, MI
The second option is on is to use the mod by @Dalehelman and @Tabaz (I think he did it also), and remove the jack handle so you can use a cordless drill to raise and lower the jack. I love this option.
I am unable to open your Amazon link, so I’m not sure which jack you are referring to.
2009 Subaru Outback R 3.0
2022 Ford Ranger XLT Super Cab
https://www.etrailer.com/question-270614.html
Jeff & Amy
You're going to tow with the tailgate down? Won't that seriously limit your turning radius? Not a big problem as long as you're observant.
Jeff & Amy
