Clamshell galley tent
Marceline
Member Posts: 1,773
Hey, Marceline I looking at the Hasika Awning Camper Trailer roof top $109 at amazon ...Ihave a 2017 CS-S don't know if it will work it shows a pic of a T@G... A lot cheaper then the $750 for the pahaque clamshell tent... good luck & shopping2017 T@B CS-S Max ... 2020 Honda Ridgeline RTL-E0
Thanks but I got murdered by mosquitoes at Diamond Lake (OR) last month so I'm looking for something that's fully enclosed. I'm trying to see if there is something that's cheaper than the PahaQue that will work. If all else fails I'll fabricate something out of mosquito netting.manny said:Hey, Marceline I looking at the Hasika Awning Camper Trailer roof top $109 at amazon ...Ihave a 2017 CS-S don't know if it will work it shows a pic of a T@G... A lot cheaper then the $750 for the pahaque clamshell tent... good luck & shoppingSan Francisco Bay Area | 2013 CS-S us@gi | 2015 Toyota Tacoma PreRunner Double Cab
Marceline, the PahaQue tail veil for the Tab is pricey and does not look very spacious. I understand the need to hide from the bugs. You may consider https://www.amazon.com/Plow-Hearth-Umbrella-Mosquito-Zippered/dp/B009YZ5RKK/ref=sr_1_2?ie=UTF8&qid=1501971010&sr=8-2&keywords=umbrella+netting. An inexpensive way to keep the bugs off.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
Amazon also has these nets, which might also work attached to a pop up awning or something. For $20 it might be worth a try.
https://www.amazon.com/dp/B01KKMZRFK/_encoding=UTF8?coliid=I3FM2PPVTMYTW6&colid=1TLEVFC9JYU7H2017 T@B 320 Max S silver and cherry red, L@dybug ("Bug" aka my esc@pe pod), TV 2015 Toyota Highlander aka Big Red1 -
Found this over on the TaG forum. If it is tall enough for a minivan, it may work for a CS.
http://www.rightlinegear.com/suv-tent.html
Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio0
