We hit some serious potholes on the most recent trip and had our class III hitch bar rotate a little, lowering the ball a little...
So I need to replace the hitch bar and maybe beef it up a bit before assembly.  But that got me thinking.  Most manufacturers tend to put the safety chain loops on the receiver, which in turn is attached or welded to the tow bar, which in turn is attached to the tow vehicle frame.
So if the receiver portion gets metal fatigue and fails, the receiver and safety chains and trailer go careening down the side of the road.  Or if the whole tow bar is pulled off the frame (e.g. sheared attachment bolts), then same result.
There are some setups where the ball assembly goes into the hitch receiver, but the chains hook onto a completely different TV attachment point.  No single point failure.
But there's as many factory towing setups where the two loops for the safety chains are just welded onto the rear end of the receiver.  As if the trailer ball socket, or the receiver ball have the highest probabilities of failure.
Not sure if that's really true. I've seen plenty of stories with pics of hitch bar failures (like mine), and even TV rear subframe failures.
Odessa, Fl.
2019 Ford F-150 3.5L Ecoboost with Long Bed
It looks to me like the thing that needs improvement is your hitch AND/OR the bolts needed tightened. I am unclear how hitting a pothole would bend the safety chain hook point?
A regular point of inspection pre-during-post trip should be your hitch setup including the hidden under TV bits.
I WILL be checking it more frequently now. It could have been low for the 1500 miles before I got home... I'd been parking on mud, snow, and uneven surfaces and assumed that was why the jack seemed lower. Lesson learned.
But hey, anything can happen on a regular set-up if the force is great enough.
and for sure, rust is not involved, metal is clean as can be.
and about safety chains, yep, they are more to secure tha attachement in case of couple failure. The hicth attachement, should start to wiggle before gving, but again if it give, at least one side should remain attached and created something weird that a driver should see and feel before complet rupture.
yours need serious repair and now reinforcement or replacement.
hope you fnd a solution. Be safe outhere.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
