Thanks
qhumberd
Moderator
Thanks
qhumberd
Moderator
Noisy Water Pump???
cowboypete
Member Posts: 37
I bought a new 2018 T@B 400 this spring. The weather in Tennessee is just getting warm enough to experiment with it. I filled the water tank up and washed out all of the anti-freeze that was in it. all went well except for the noise. Whenever I have water running there is a loud rumbling , rattling noise by the bathroom wall. It quits when I turn the water off. Is this NORMAL for a R@B 400? It really is loud and annoying. Thanks for any help you can give me.
Bob & Irene 2003 F150 V6-Manual
2018 TAB 400
Nashville, TN.
2018 TAB 400
Nashville, TN.
I have a 320 and the water pump is a bit noisy. I’m guessing that it is much the same with the 400. Some people have attempted to muffle it a bit, but I hardly notice it anymore, once I found out it a “normal” thing...Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI -
Normal...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
Pretty much normal. Just run the air conditioner--that will drown out the noise of the water pump.
RV water pumps can be noisy and that is exacerbated by the on/off cycling. Attempts to quiet the pump include using vibration isolating mounts and care as to which surface the pump is mounted. To reduce the on/off cycling you can install a pressurized accumulator tank on the output of the pump. Those are available from Shurflo and other manufacturers.
Thanks everyone for your replies. If it is :"normal" and not ready to shake itself to death, I as sure that we can learn to live with it.Bob & Irene 2003 F150 V6-Manual
2018 TAB 400
Nashville, TN. -
One thing that can cause excessive noise is if the hoses to/from the water pump are touching or close to the wall, normal shaking during pump operations can cause the hoses to bang against the wall. If you can access the pump hose with the water running, you might find that the noise if reduced when you hold one or both of the hoses. While I have not done this yet, some split water pipe insulation from a hardware store wrapped around the hoses could help a lot.T@B 320 manuals and electrical drawings
2023 Jeep Gladiator Sport S, Max Tow Package. -
Great advice, That sounds like it would help quite it down.
Do you know where the water pump is exactly? It sounds like it is probably behind the wall on which the shower head is mounted, but I was hesitant in just pulling panels off the wall of my brand new RV to try and find it.Bob & Irene 2003 F150 V6-Manual
2018 TAB 400
Nashville, TN. -
@cowboypete The water pump would be found in a compartment that is accessible inside the closet. The bottom of the closet floor can be lifted out and there is the water pump.
Pam and JohnChamplin, Minnesota2018 T@B400 and a 2025 Ridgeline Trailsport
We found the same noise issue - sounded like it was coming apart. The piping on either side of the pump was hitting the wall and the edges of the holes where the pex passed through. I added a snap-in pex clamp spaced out from the wall with a wood block so it would keep it's normal routing. It worked great. The following link is from Menards (big box store).
Tim & Joan, Anoka Minnesota
Silver on Silver 2018 T@B 400, 2018 GMC Sierra 1500 Crew Cab -
Great idea, @MNtabernacle !2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Thank you all for the great information and ideas. I will look at the pump and take your advice. Thanks again, CincycowboypeteBob & Irene 2003 F150 V6-Manual
2018 TAB 400
Nashville, TN. -
This is actually a great idea. I have looked into the closet access area of the 400 and if I can slide some pipe insulation up the PEX lines it should help out and make a difference. My wife has never been happy with the sound and vibration of these pumps in both the 320 and the 400, but unfortunately she has exceptional hearing so it’s more noticeable. I have some extra time now that we are back home and I’m going to look at the pump area more closely and see if that area can be better sound proofed to at least muffle or deaden the noise emanating out from the compartment.klenger said:One thing that can cause excessive noise is if the hoses to/from the water pump are touching or close to the wall, normal shaking during pump operations can cause the hoses to bang against the wall. If you can access the pump hose with the water running, you might find that the noise if reduced when you hold one or both of the hoses. While I have not done this yet, some split water pipe insulation from a hardware store wrapped around the hoses could help a lot.Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ
- 916 Introductions
- 72 Teardrop Groups & Links
