Tail light
cotracye
Member Posts: 9
I sprayed wasp killer in the tail light as they moved in there. It shorted out the tail light and I need to replace it. Any ideas?? Where can I buy a new tail light for a 2008 T@B?
@cotracye, nüCamp bought the remaining Dutchman stock of spare parts. Call any nüCamp dealer to order one. The dealer can have it drop shipped to you if nüCamp still has the parts.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus. -
One idea:
Look at a place like etrailer and see if they have something that would work.
You could swap out both lights with new LED lights.
https://www.etrailer.com/dept-pg-Trailer_Lights-sf-Tail_Lights.aspx
Was the light powered when you sprayed? After the spray evaporates there should be no lasting effects I would think. If it was powered on, they you may have blown a fuse on the tow vehicle? If the bulb is burned out, is that replaceable? I know nothing about that particular tail light, but I don't see how wasp spray would kill the fixture permanently?2019 T@B 400 Boondock Lite
It was not powered on at the time. I tried changing the bulb and still no go. It worked prior to the wasp nest issue.
There was a common LED unit swap detailed a couple times on the Yahoo T@B forum. I also remember a youtube from Richard Lewis.The CS uses a common Bargman rectangular unit.
Here is the Richard Lewis file. If you need more info, just ask (I did this swap myself because of cracked light).
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
