I was wondering if anyone had experienced an issue with the 12 V water pump continuing to run after the taps have been turned off. If I allow a full flow of water, the pump changes sound and when shut off the pump stops within 10-20 seconds. If I only open the tap slightly the pump continues even after the tap is turned off. The same issue occurs when flushing the toilet. I have a full tank of water and am plugged in to shore power so the voltage to the pump is good. Note that this is a new T@B and this is the first use to the fresh water system.
I do get a good flow, so I am not expecting its an issue with the pick-up. Once the pump turns off, it stays off, so I am not seeing it as an issue with a leak or open drain valve. All of the by-pass and drain valves are in the correct positions.
0 ·
(formerly a 2013 T@B Q M@X); 2015 Jeep Sahara JKU (Max Tow)
Toronto ON Canada
Toronto ON Canada
In in doing a bit of research it is possible that the pick up tube going to the tank may have a loose connection and may be allowing the pump to take on air, which will have an impact on its ability to create the necessary pressure on the output to trigger the pressure switch. It could be a loose pipe clamp on the tank. I will check it when I get a chance.
http://tab-rv.vanillacommunity.com/discussion/2547/water-pump-issue-solved-2016-t-b-q-max-outback-edition#latest
