Drainage of Dometic Cool Cat on 400
peterac50
is there a drain on the pan for the cool cat air conditioner. Noticed water dripping out the exterior grate.
(Edited: Just fixed your domestic cool car. Sharon)
Peter and Nicki; Quechee, Vt
2019 Tab 400; 2019 TV Honda Ridgeline
It does drain out the corners of the vent. We always level with a slight down and forward to that side.2018 T@B 400, 2017 Nissan Titan Crew cab1
Just got this update from Nucamp tech department: There is a drain system for that ac. Once the pan underneath the AC fills to a certain point there are cutouts on the bottom of the exterior ac exhaust grill. If you feel the bottom side of the Grill you will feel 2 drainage ports.This is the drain pan system we received from Dometic with their AC.Peter and Nicki; Quechee, Vt
2019 Tab 400; 2019 TV Honda Ridgeline0 -
Are there actual drains out bottom for the 2021 400's with the Cool Cat? The previous models while maybe draining with the cutouts, obviously do run down side of trailer below the grill, certainly would of been better with some sort of tube through the floor.2019 T@B 400 Boondock Lite0
I believe the 2021s are using a dometic pan with drains out the bottom - but someone needs to confirm that. I believe I read that. That is why my question to Nucamp was about a possible retrofit - but that does not appear possible due to the previous design.Peter and Nicki; Quechee, Vt
- 144 Events & News
- 415 Service/Maintenance & Recall Notices
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
