refridgerator door rubber seals
kaylevine1
Member Posts: 165
the black rubber seals around the refridgerator door came loose within a few months of purchase-I imagine because of the high heat-what kind of glue is safe to glue them back on with??
Goop has been suggested, see:For mine super cleaned the rubber and channel, then pressed the rubber back into the channel (no glue) and it seems to be holding now.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
Ditto!!MuttonChops said:Goop has been suggested, see:For mine super cleaned the rubber and channel, then pressed the rubber back into the channel (no glue) and it seems to be holding now.TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
done that already but maybe I didn't clean it well enough-will try again-right now seems to come loose every time you open the door-remember it is very hot and humid here-temps got above 100 inside the trailer last summer
If you use goop use it sparingly. It won't take but a thin layer to hold the gasket on--once it has dried that is.
Mine came off last year. I used RV Goop, just a dab on each corner. I didn't see any old adhesive and pressing it back into the slot didn't work for me. Hopefully the Goop holds this year.Debbie in Oregon
Sold 2023 Tab 400
Sold 2018 T@B 320S -
well I used the rv goop since I had some-we'll see if it holds-thanks
We used gorilla glue and it has stayed in place
gorilla glue was going to be my second choice-I have some so if the goop rv doesn't work I will try that
so far so good-no problem on my June almost 3 week camping trip the rv goop held so far
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
