hi folks, glad to join and take advantage of your knowledge and experience...on the weekend I was de-winterizing and getting my TAB 320S ready for the season (in canada so season starts much later!!).  I filled the fresh water tank and charged my plumbing lines after draining RV antifreeze and then activated Alde at the thermostat to heat water in the Alde hot water tank just to test it.  At that time I was running on propane only but I noticed two things...first was a slow drip coming from hot water out side of hot/cold mixing valve and also noticed after a few hours that I couldn't get the water hot.  The second issue is not urgent but I'm a bit concerned about the slow drip and wondered if I need to go find a dealer or something I could tackle...appreciate any comments/suggestions.
thank you!
                0 ·
https://tab-rv.vanillacommunity.com/discussion/6811/need-help-mixing-valve-leaking
Regarding the hot water, is the Alde itself not heating, or is the water coming from the tap not hot? Do you have the digital display? If so, you can check the water temperature via the display.
