Tab 400 table
NinabeanNinabean Member Posts: 68
how do I detach the table so I can make a bed out of it?
2019 T@b 400 “Hazel”   Towed with a 2013 Ford F-150 STX  4X4 SuperCab 5.0L
table mod
  • NinabeanNinabean Member Posts: 68
    Yes.  There are two gray latches of some sort that attach to a rail.  There is another rail underneath the table to attach it to to make it into a bed.  I cannot get it to unlatch.
    table mod
    Push on the buttons on the underside of both of the latches.  It may take more than one try. Be patient and they will both unlatch at the same time.
    Then lift the table upward when it unlatches.
    When it is loose, push the button on the single leg so it folds in half. Then put the latches on the lower metal strip on the front wall. Allow the latches to connect to the metal strip, make sure both latches are connected securely, make sure the leg is still folded in half, put your cushion on the table top and make your bed.
    Questions?
    Ok I figured it out by crawling under the table and pulling back on the tiny tabs in the latches.  That is hard to do and seems to me a two person task.
    table mod
    Thank you @Verna🙂
    table mod
