Boondock Edge storage tray on TAB 400?
I understand the new 2020 TAB Boondocks come with the more useable Boondock Edge style front storage tray. Is it possible to order and install such a front storage tray on a 2019 TAB? Cost? Tongue weight issues?
2019 TAB 400 Boondock
    Due to excess tongue weight, I think the aluminum platforms were not an option for the 2019 400 Boondocks.
    NuCamp rearranged bits and pieces on the 2020 400's in an effort to take some weight off the hitch. They added it back with an optional way to store more stuff :) the new platform should bolt right up, if your tow vehicle can handle the weight which will likely exceed 500 pounds hitch weight if you add the rack and use it, then I see no issues as long as you don't go too crazy with adding weight to the platform. At some point I suppose you could stress the frame?
    I am considering adding the rack to my brand new 2019 Tab 400.
