I'd like to install some eye bolts or pad eyes in the floor under the rear seating area for securing storage. Part of the floor is flat ( with vinyl floor finish ) but the rear section is sloped up and appears to have an exposed plywood finish. Is there plywood directly below the vinyl floor finish for screwing things? Is the slopes floor finish plywood? If so how thick?
Thanks
I was very careful and predrilled small shallow holes, then ( to prevent any moisture from entering) I filled the holes with nonadhesive caulking and used fairly wide but very short stainless steel screws.sabel said:Rad,
What did you encounter when doing your table mount? How did you secure it? I'm sure it's the same under the seats.
The picture is the closest I can come to showing the construction of T@B during a factory tour at Tearstock, and yes, I know it's the front, not the back.
The best answer I can give, and I've already given this answer two other times this evening, is to call the factory and talk to whomever answers the phone. Be patient, yes, you have been patient, but the office personnel can't always get to the correct person with the answer you want when you call. Ask for any one who has knowledge of where you can put the bolts. I'm thinking there isn't 3/4" plywood in the T@B's, to keep the weight down.
Good luck, Sabel.
Rad, that's why I recommend calling and talking to whomever answers and asking to be transferred to someone there. Both Ed and Marvin are great sources of information, but that means that they have a lot of work in the factory--answering questions, helping with problems, trouble-shooting, etc. That's why I don't refer to anyone to specific people. Emails and returning phone calls are last on their list, unfortunately. Talk to a live body, if at all possible.
If you get the opportunity, take a factory tour. It's non-stop action, and no time for chit-chat.
I understand, sort of. I always found it much easier to give good customer service in my working days by email rather than phone. I could pick when I responded.Verna said:Rad, that's why I recommend calling and talking to whomever answers and asking to be transferred to someone there. Both Ed and Marvin are great sources of information, but that means that they have a lot of work in the factory--answering questions, helping with problems, trouble-shooting, etc. That's why I don't refer to anyone to specific people. Emails and returning phone calls are last on their list, unfortunately. Talk to a live body, if at all possible.
According to this video of a T@B being constructed in Germany, the base is made of plywood. Pretty sure it would need to be something like that in order to be strong enough to walk on.
PXLated said:Verna - We appreciate you and Mike - You're our most reliable channel to the factory.
Thank you. I try.....very trying at time
Obviously I enjoy this, lots of challenges, lots of learning, and I try to be as informative as I can. It's amazing what I have learned about T@B's and I have actually never set foot in one. I haven't checked one out for how much storage there is, but I can about tell you how everything works....except the Alde (I think that's a hands-on learning experience). All of the pictures obviously show me a lot--thanks for all of those. Soon, we'll even know how the floor is constructed--note, I said "we".
Makes sense, other than when I drilled my pilot holes for my table it sure did not respond or feel like wood. There was no resistance to the drill bit or any wood shavings or splinters that came up or stayed on the bit. Could be I was not paying attention, who knows. I look forward to the factory answer.Bentr said:According to this video of a T@B being constructed in Germany, the base is made of plywood. Pretty sure it would need to be something like that in order to be strong enough to walk on.
Thank you, Rad.
By the way, Scott is in the "factory", so Sandra's answer from Scott is the way the floor is constructed.
Thanks, I missed that post....guess what, I'm not crazy, read the floor construction noted above in Sandra's post........no plywood. That does not make it a weak floor, the aluminum framed foam makes sense. Sounds even better for a wet bath rig. Less chance of a delaminating plywood floor like some of the Airstream Bambi's have been known to do.Verna said:Thank you, Rad.
After personally seeing the damage to plywood in a 2007 LG 6-wide owned by Indycamper on the LG forum, I'm also glad the T@B's are going away from having wood as a structural member...says the woodworker here. Indycamper's 6-wide cabin's plywood floor and walls were disintegrating within the walls. Pleasant Valley replaced the entire cabin (for a very good price, of course) for a 2013 cabin on her 2007 frame.
So, if the composite floor is being used in the T@B's, I applaud them for their changes. I remembered that Cyclonic said that his T@B's floor was spongy (or something like that), so I figured there couldn't be plywood in the floor.
(And, by the way, the 2007 LG was made by the previous company, The Little Trailer Company out of Elkhart, Indiana, not the current manufacturer, Pleasant Valley Trailer Company.)
Might consider a plywood (or other hard material) backing plate under the T@b floor to spread the load more than the washers will. Assuming the underside is clear where you need the backing plate, of course.mawebb said:I wish to install a table pedestal, and am planning to use bolts through the floor, so hopefully it is substantial enough to take the bolts and hold the base secure. I will use large washers on the underside.
I wikied Meranti and it's Luan, so Azdel would be a far better choice for flooring.Verna said:Thank you, Sandra. I found the definition of "azdel" as being a composite being made since 2006 for the RV industry, but I was unable to find "miranti", but I would assume it is a composite also. So, not much to anchor to in the floor.
Be sure to check out Fender Washers at Lowes, Home Depot, etc.....they are much bigger than an ordinary washer.USWildflowers said:Might consider a plywood (or other hard material) backing plate under the T@b floor to spread the load more than the washers will. Assuming the underside is clear where you need the backing plate, of course.mawebb said:I wish to install a table pedestal, and am planning to use bolts through the floor, so hopefully it is substantial enough to take the bolts and hold the base secure. I will use large washers on the underside.
