Using Surge Protector with Generator
System
Administrator Posts: 192
This discussion was created from comments split from: Budget Built-In Surge Protector.
Need help. Boondocking and connected my Honda 1000w generator to my TAB 320. Recently installed the Progressive Industries hard wire surge protector. With the Honda running, no power to the outlets. The PI shows Error Code E2 - open ground. Does this mean I can't use a generator with The PI unit? Did not have this issue prior to the PI install.2016 Outback 320
Hey, @Tabaz , read this thread about how our friend RZRBUG took care of this: https://tab-rv.vanillacommunity.com/discussion/comment/30948#Comment_30948Verna, Columbus, IN
Thank you Verna! Good to know there is a solution to this problem. I take back any nice thing I've ever said about Progressive Industries. There was nothing in their manual about generator use - or their optional $18 add-on. They must assume all their customers just camp at established campgrounds with big, beautiful pedestals. Thank God I'm not in a Donner Party situation during this trip.2016 Outback 320
2024 Ford F150 Supercrew short bed.1 -
^^ This issue is really not a Progressive problem. The problem lies in the generator design. Every Onan RV generator I've had (several) has the neutral and ground bonded at the generator. This seems to be an issue for portable generators. As I've mentioned in other posts on this subject, I permanently bonded the neutral and ground on the back side the generator 20 amp receptacle. I cannot conceive of any application where this would cause an issue.T@B 320 manuals and electrical drawings
2023 Jeep Gladiator Sport S, Max Tow Package.0 -
VERY simple solution. Buy a $4.00 3-prong male plug end, put a jumper wire between the ground and silver neutral posts, screw it back together then plug it into an open outlet on the generator. Works like a charm. My complaint with PI is they don't mention this anywhere in their literature. That to me is shameful.2016 Outback 320
Besides bonding the N-G legs, another option is all the PI units have a bypass switch, the whole idea of the PI unit is to protect form issues with grid power of unknown quality. It seems if using an inverter generator the probability is about nil of getting bad power to the trailer, so you could just flip the bypass switch while on generator power and be pretty safe.2019 T@B 400 Boondock Lite0
My PI unit EMS-LCHW30 does not have a bypass switch. It appears PI makes a model with a remote monitor that does have the bypass function.2016 Outback 320
The hard-wired units with the built-in display (no remote) may not have the bypass switch, but I haven't verified.T@B 320 manuals and electrical drawings
The bypass method for the non display units is a jumper inside the PI. Not user friendly.2020 Tiffin Open Road2020 Nissan Versa Toad
Alan & Patty
Southern Az0 -
@RollingBnB that seems like a failure at the design stage to not include a bypass switch! Gotta say I am pretty happy with the built in PI unit with remote display + bypass switch.2019 T@B 400 Boondock Lite0
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
mine is built in and has the remote display with bypass switch.
