 sabel
                    Member Posts: 283
sabel
                    Member Posts: 283
            So today I decided to remove the spare tire from our Outback. I was concerned that it was just a little too much weight bouncing around on that Yakima. After removal, weighed tire and mounting hardware. Came in at 60 pounds. IMHO that's too much of an eccentric load on the rack and roof.
So now the debate shifts to the question of eliminating the spare tire entirely and carrying a Slime Tire Repair Kit. In the past 35 years, all of my flats ( including motorcycles, knock-on-wood ) have been slow leaks by nails or screws that were repaired by driving to nearest tire store. However someone mentioned earlier that trailer tires may get shredded before you even know there's a problem. Good point.
Comments please.
I recommend go find a good welding shop and talk to the fabricators about welding up a spare tire mount. A good fabricator can have great ideas. Also search the internet for what others have done - from horse trailers, construction trailers, to travel trailers. Take some examples to the fabricator to get the ideas flowing. Or go buy a nice MIG welder and get to work.
Durango, CO
2015 S Outback
How does it go? A picture is worth a thousand words? Perfect explanation Verna.
The worst blowout I've ever had was crossing a railroad track where a spike had come out - Not only went thru the tire but right through the rim as well. And to the meme that you never have a flat on a nice sunny day, It was night, I t was -5 degrees and I couldn't find my scissor jack handle. Managed to get it jacked up using the handle from an xacto knife - still can't believe it worked.
the right lane. The Silver Shadow tilted up on the left tire, so I swerved back to the right, and the right tire slammed down, blew and also bent the axle. A few more moves and I had it under control. AAA changed the tire and I limped home, not knowing the axle was bent. State Farm took care of all damages except my $100 deductible--rim, tire, melted trim around the fender and a new axle, plus installation of all of it. That night was not one of my favorites. Don't even get me started on idiots who don't have the time to drive less than 5 miles to the next exit when they miss their exit!
I do now carry an 8 ton Harbor Freight bottle jack, plus the lug wrench I mentioned. Except on a busy interstate, I can change my own tire.
Melinda,
Haven't towed it since removing spare. Weather has been too bad. Snowing here. But it towed very well with spare on top. Don't expect any changes but will report back.
