Tail Lights
gspdx
Member Posts: 208
I noticed some of the lights are not lighting up in my left tail light on a 2019 T@B 400. Anyone know if these can be replaced individually and how do I remove it?
Thanks,
Gary
Thanks,
Gary
2019 T@B 400 BDL
PNW
PNW
It's all one unit. The entire light needs replaced. If you have owned the 400 less than a year, it is under warranty and contact your dealer. If over a year, you can still contact your dealer.Verna, Columbus, IN
Thanks. I bought it used so I am supplying the warranty I think.
2019 T@B 400 BDL
PNW -
Just so you know, not that this is pretty or effcient, but technicaly, as long as one pixel is still on and is doing the job it is supposed to do, according to the law, you are not at fault. This is the beauty of the led light system.
But the more that are working, the better you can be seen by other, and it does not look good when even just one goes bad. But this is me.
TV 2005 jeep TJ unlimited
Alaskan Malamuthe on board!
Les Escoumins and Petite-Riviere-St-Francois QC -
I love skirting the law!! 😏Luckyj said:Just so you know, not that this is pretty or effcient, but technicaly, as long as one pixel is still on and is doing the job it is supposed to do, according to the law, you are not at fault. This is the beauty of the led light system.
2018 320S Outback -
LOL! Yes - I think we are OK at this point but would like to have all of the lights working. Thanks.4ncar said:
2019 T@B 400 BDL
PNW -
I had to replace one on our Tab 320. It was an okay install, but I didn't realize that I had to take off the plastic around the light and also on the side. Then the wiring wasn't the longest to wire the new one to. ( I was under warranty and the company sent me a new one btw)Terry & Jody... 2025 Honda Ridgeline RTL
2016 NuCamp 320 T@B Max S
T@bbey Road
Appleton, WI -
All this you speak is truth! Could they have given us 3” of slack?🤬TerryV6 said:I had to replace one on our Tab 320. It was an okay install, but I didn't realize that I had to take off the plastic around the light and also on the side. Then the wiring wasn't the longest to wire the new one to. ( I was under warranty and the company sent me a new one btw)TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback -
It all ended well however... I have pics here somewhere...Terry & Jody... 2025 Honda Ridgeline RTL
T@bbey Road
Appleton, WI
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
