I’ve been tent camping for years but since having a family, that has slowed down. My wife has agreed to a camper and I’ve focused on a T@B S. Our family of 4 (4 and 2 years old) frequently take trips in our 2017 Odyssey. Im told to never approach the tow rating. Would I have any trouble towing our family, luggage and a T@B? Intend on traveling mostly flat trips within 250 miles. Thanks, Andy
0 ·
My Two Cents - - - if even worth that
Let's look at some worse case numbers.
First, factory towing capacity:
So you don't have 3,500# capacity; 2 Adults and 2 small children = 3 Adults. If you also have a large dog or Grandma comes along you're at or above 4 Adults . . . . Tow capacity at sea-level is 3,200#
Next tow capacity is derated based on altitude at 3% loss per 1,000 feet
If your hometown and primary camping areas are around 2,000 Ft elevation your towing capacity nearly equals the maximum 320S weight (GVWR)
At 2,000 feet elevation you will be towing ~ 2,355 pound . . . . 78% of maximum rating
Suggest you do the above type of analysis for your situation and then decide what % of margin is comfortable for you. Personally, I'm more comfortable towing at 70% or less (lower better) of TV maximum towing capacity or "a margin" of 30% or more.
Don't Forget:
Honda OM says you need the factory tow package or at least a Transmission Cooler to achieve the maximum ,3500# rating. They also state on page 402, that Honda does not recommend WDH (most T@B's don't need it) but keep that in mind.
In general Honda has useful towing information in their owners manuals which is true for the Odyssey as well. Compared to a Ridgeline there is not nearly as much information so it could be safe to assume Honda does not consider the Odyssey as a towing platform . . . it can tow but that was not a primary design criteria.
If you decide the Odyssey is OK for your situation go for it. If the future brings greater distance and longer duration trips a different tow vehicle would most likely serve you better.
Thanks, Andy
I believe you will be very happy with T@B-Odyssey combination. . .
T@BMahal
'04 #100
