Hi, I'm new here. I bought a 2005 T@B a few weeks ago. I want to purchase a solar panel, but can't find any info about the appropriate connector type. My T@B has a capped outlet on the outside of the propane/battery case. The wires attach to a charge controller/inverter, then go to the battery. Does anyone know what the name of this type of connector is? It has 4 prongs, and is about the size of my thumb. Any help and advice would be greatly appreciated! Thanks!
Durango, CO
Durango, CO
Durango, CO
Now, back to your plug - Where is it mounted, on the T@B body or the propane cover?
2005 Dutchman T@B & 2010 Toyota 4Runner
Typical setup: solar panel -> charge controller -> battery -> inverter (DC to AC). Now, the installer may choose different plugs (like the one you have) or the 2 prong discussed above to provide a quick disconnect for portability. Choose the correct disconnect plug that you are comfortable with.
Durango, CO
Since it's on the cover I think I'd just replace it with a shiny new Zamp style connector from the factory - unless of course all four wires are actually being used and you can figure out what they are.
Lazulibunting, if you were to order a Zamp Quick Disconnect from Elsie at the Pleasant Valley factory for around $30 + shipping, you would receive a 2 conductor waterproof plug-in that mates with the Zamp brand of solar panels that the Little Guy Teardrop store sells (golittleguy.com and select "store" at the top of the page). There is about 18" or so of 10 gauge wiring on it that would connect to your battery. You could replace your 4 conductor plug with the 2 conductor plug.
Zamp makes their solar panels with the waterproof PWM controllers attached to the rear of the solar panels. Then, there is about 20' of wiring that would connect to the battery via the quick disconnect plug. The panels are portable so you can move them with the sun's movement.
What you have now has the controller/inverter inside your tool box, which is not compatible with the way that Zamp has their solar panels wired. If you are knowledgeable about solar panels, then you could use what you have, and you could use another name brand of solar panels that may or may not cost less. Your controller, depending on which kind it is, would cost between $30 to $200. If there is a separate inverter, then that cost goes up, depending on how many watts it will handle. What I am not familiar with is the fact that you have a 4-conductor plug. Are there only two wires connected to the converter from the plug and then two wires going to the battery from the inverter, or are there more wires?
I'm not sure if you have the solar panels that were used on your T@B. If not, sometimes it's easier to start from scratch, unless you can figure out exactly what you have and how to adapt it to solar panels that you may need to purchase.
Good luck. Ask if you have more questions.
While I like the price of the Renology panels, their controllers are not waterproof, but Zamp's are. My research has shown the controller is better at the portable panel(s), rather than at the camper. But, if your controller is not waterproof, by all means shelter it inside. The lost Amps would be less expensive than having to replace a controller that got wet.
I want 200 watts in a suitcase form, which Renology doesn't have. By the time I bought two 100 watt Renology panels, found a waterproof controller, bought the wiring and connectors, built a wooden suitcase, I would be close to what Little Guy's Store wants for their 200 watt Zamp suitcase. Don't forget to buy the $99 VIP annual membership to the store for 20% off to save some money, if you're going to spend over $500 (I think that's the break even price-correct me if I miscalculated in my head!). (No, I am not a Little Guy employee, just a volunteer.)
So, I do need to question you about what you are calling your controller/inverter. I've not seen the two of them combined. What is the brand name? It sounds like an inverter with the plug-in into the 12V plug, but I do admit that I don't know everything. I'm curious about it.
If you do already have your controller, and if it's amps will handle what the 100 watt Renology suitcase puts out, then you're ready, after you replace your plug with one that is compatible with the suitcase panel you purchase. I've only seen the mountable quick disconnect in Little Guy's store, but you can buy the mating quick disconnect from Amazon or even in a sporting goods store at their trolling motor section. Then you can splice the mating quick disconnect to your wiring and plug it in. Then just watch it charge your battery!
By the way, the photo Little Guy is using for their 200 watt Zamp is my current setup. 80 watt Zamp connected to my Silver Shadow, and taken this past January at Coyote Howls campground in Why, AZ. It worked marvelously!
Questions?
In my experience, that waterproof controller is important - unless of course you want to hide one inside. Can't count the number of times a quick shower has developed while my panels were out, many times when I wasn't anywhere close by to store them away or protect them.
And I agree that the waterproof controller is very important. And I love the plug and play, too.
PXLated, I broke two of them, so I have extras, too. Plus I keep my electrical repair kit handy. It is well stocked!
I think you have a very early model of a solar controller. The ones that are manufactured today are 3/8" deep, 4"x4", or a similar size, digital display with printed circuit boards that are small. Yours reminds me of telephone equipment from the 70's!
So, your 4 conductor connector probably only has two wires connected that go into this convertor, and it then comes out of the converter to go to the battery. But, the inverter part will only allow you to get DC voltage out of it, and not 110V for things like the receiver of a satellite dish. It is probably not a pure sine wave and shouldn't be used to plug laptops or other electronic gear into.
My advice is to purchase a newer solar controller, a newer connector to replace the 4 conductor plug, a new solar panel of your choice, the necessary wiring, a new inverter and a mating connector (like the 2 conductor ones PXLated and I have been talking about).
So, if you want the Renogy 100 Watt suitcase you can have it, but I hope with a new controller.
Where to now? It's your decision on how to proceed.
And, by the way, I'm leaving tomorrow for a weekend of camping and won't be back until Sunday night. I don't mind brainstorming this with you, but I'm planning on being out on a kayak fishing, talking to friends, enjoying the out of doors, and I won't have much time for computer work this weekend. I can help next week.
No, Mike and I don't own stock in Zamp. We are very satisfied customers of Zamp and have had very good experiences camping with them.
We are not familiar with your equipment, so we can only give you our experiences with our Zamps. If you're satisfied with what you have, then go with it. You asked a question and I gave you my best answer. My answer did have Zamp in it because that is what I am familiar with.
It's certainly your choice to use whatever equipment you want, and please don't be offended by any suggestions provided here on the forum because there is a wealth of experience, knowledge and information spread out among the members (who willingly provide it) and this is what the forum is about. I'm on a budget too and cannot afford some of the equipment other members own so I certainly know the feeling. But if I can help another member based on my personal experiences of using similar equipment and any additional knowledge gained from others I'll continue to do just that. People have choices, can glean whatever information and tips provided via the threads posted here and it is also available for future/potential owners to benefit from as well.
