Adding glycol to Alde
gooselady
Member Posts: 177
Ok, I'm really inexperienced with any sort of maintenance, but I found my Alde reservior and it needs about an inch of glycol. Thanks to this forum and to Amazon, the glycol will arrive tomorrow. Do I just open up the top and add some? Sorry to be such a noob.
The Glycol from Elsie or Amazon is premixed. Just use a funnel to put the Glycol into a water bottle, then use the funnel to pour the Glycol into the reservoir. The water bottle makes the task more manageable.Verna, Columbus, IN
Thanks, Verna! I read through about a dozen threads looking for this answer. Any bleeding needs to take place?
You should not need to bleed. That should only be needed if you are changing out the Glycol for fresh glycol.Verna, Columbus, IN
Perfect, thanks.
anybody know how much glycol needed-the level is pretty low-going to try to figure out how to get to the reservoir and fill tomorrow morning while not so hot-it is hot as you know what here in the afternoon-also my first time-I see it in the corner of the closet but don't know how to actually get to it-I,m assuming screws and unscrewing will be involved
Just picked up my new 2020 Tab 400 BDL 2 days ago. I have noticed that the glycol is just a bit low. Does the greenish glycol that is ordered from Amazon mix well with the already existing more blue colored glycol that is already in the system?Thanks,LeePisgah Forest, NC2020 Tab 400 BDL2014 Toyota Tundra 5.7L Crewcab
On the 400 with the small fridge, the gray plastic cover should come off no tools, just left up and out. The fill cap is on top the reservoir, unscrew and add fluid. I would add to MIN mark when cold. There is a good bit of expansion when hot, you run the risk of burping glycol out if you add too much.
AFAIK, the factory fluid is identical to the Amazon fluid.2019 T@B 400 Boondock Lite -
If it's just a little low, I'd wait and monitor when the system is heating. It won't hurt anything, and if you add fluid now it may just be burped out.
If it is on the low side while hot then I'd add a little.2015 Max S Outback | 2010 Xterra -- Retired
2022 Ford F350 Tremor | 2022 Cirrus 620
- 920 Introductions
- 74 Teardrop Groups & Links
