Hi everyone,
Last week i was discussing  with a colleague how I liked my tab and seeing new things while camping. And I mentioned to him how I was finding annoying the knocking of the trailer while driving and i could not believe  that with the qty of trailers on the road this was the norm and nothing was invented (pls keep in mind that the tab is the first trailer i have towed in my entire life). Btw i purchase everything i needed to stabilize my hitch the only part loose i s the ball in the coupler. This is when he told me have you adjusted the thighness of your coupler? I said no, so he explained to me that theres a bolt inside the coupler for fine adjustment. I was all happy to learn this thinking my issue was solve. Got home, laid down under the coupler no bolts. Heres my question is there an adjustment and I lost it or theres none and theres nothing to do? I did some search here but everything is in regard to the hitch not the coupler. Thanks in advance. Eric
                0 ·
Do you have a standard hitch with electric brakes, a newer T@B, or an older T@B with surge brakes? This changes the possible answer. If you don't know can you post a picture?
Eric; Your observation of the bottom of the coupler is correct. There is no Ball Clamp Tightness adjustment screw/bolt on a Yoke Style Coupler.
If you do indeed have a 2-inch tow ball then there can be no “coupler – ball” movement if the coupler is correctly latched. Excluding of course unless the coupler itself is in some way damaged.
As others stated the bumps you feel while towing are most likely the tow bar moving in the receiver. Receiver Clamps / Locks like the one posted by @jkjenn will stop the tow bar movement.
Following figure is from the Yoke Style Coupler patent.
When Latch Handle [38] is down and the Latch Teeth [36] are fully down in the coupler slots,
the Clamp Assembly [18] is pulled forward toward the tow ball placing
the Clamping Plate [20] in direct contact with the tow ball.
Sweetly home, I have a 2016 Tabitha with electrical brakes not sure if they are surge or not. The knocking sensation does not come from the breaking process though it’s when I roll over bumps or bad road conditions.
