Here is the completed mod.
Diamond plate aluminum installed forward of tub, stainless dog bowl with threaded rod hole the propane bottle in place, I purchased a longer propane hose to accommodate the routing down under the front and back up to the valve.
Twin 6-volt 208 Ah batteries placed in the tub with two extra propane bottles fit snugly between the battery boxes as noted from a previous post.
The bike rack mount works great, I was able to install a small PVC pipe on the mount to hold our jack handle, drilled a hole for a D clip to prevent it from falling out.
I removed the original 4" PVC fence post and upgraded to a 6" after purchasing a sewer hose set-up with elbow that was a little too snug for the smaller post
2019 Ford F-150
North Carolina
2015 T@b Max Q
2019 Ford F-150
North Carolina
2015 T@b Max Q
I was looking at Up N Front as well (https://upnfront.com/) But I'm not sure this rack allows for enough room with a standard 2" hitch bike rack that I already have for the car alone. Up N Front mounts forward of the propane box.
2019 Ford F-150
North Carolina
2015 T@b Max Q
2019 Ford F-150
