Is there a solid wood post/plywood wall between the drivers side kitchen wall & the shower door? There is a small area on the vertical wall between the Jensen stereo and the edge of the shower door that I would like to mount one of those expandable mirrors on & want a solid surface to screw into.
I know there is a wood post on the wall closest to other side of the shower door (where it opens)/wall between the television wall & bathroom, I already have a rotating coat hook hanging there.
Thanks for any info!
2018 Tab 400
0 ·
Now I do not know the true wall construction, factory floor build pictures suggest areas of the wall are thicker than others. Try removing the SeeLevel Panel and looking into the wall. Then maybe doing some very small pilot holes to confirm thickness and type of material.
