Questions on installing vent fan cover
Hello all--  I purchased a vent fan cover for the fantastic fan and will need to see if a mobile guy I've used before will install it for me as I cannot do this myself.  For anyone who has installed one, is it possible for a tall man to be able to lean over from a ladder to install this without having to set-up a platform of some kind to lay across the roof?  I sure wish they could make these kinds of accessories accessible from the inside for installation.
2018 Tab 400
    I am relatively tall 6’5” and I installed an Aerovent hood on my 400 off a ladder. Carefully leaned over the roof and installed in about 90 minutes.
    2013 Tundra TRD 5.7L
    Massachusetts
    @DenisP "relatively tall"---LOL---you're like one foot, 4 inches taller than me, so, yea, you're relatively tall.  Thanks for the info--I was hoping that someone taller would have done this without having to build a platform and was able to just lean over from a ladder.
    2018 Tab 400
    I have installed two Aeroflo vent covers. One on a Silver Shadow teardrop (not much taller than me) and on my 2014 T@B S Max. I am 5’4” and I took my time. It just takes a 6’ step ladder and move it from side to side. Follow the instructions, do not put your weight on the roof and it will look great.
  • rcuomorcuomo Member Posts: 319
    I’m just under 5’9” and I used a 3 step ladder and was able to do it by slightly leaning on the roof.
    Huntington LI
    I’m afraid of heights & get the quezy vertigo thing— don’t do ladders
    2018 Tab 400
    edited August 2019
    Ikc001- my bad, I used this 4’ work platform, not a regular ladder:
    Huntington LI
  • TallCamperTallCamper Member Posts: 2
    Hi All, I pick up my new Tab 400 in 2 weeks (1st time rv’er), so I am in heavy learning mode: why install a vent cover?
    2020 Tab 400 Boondock Lite
    Toyota Highlander XLE AWD
  • MiquelCamoMiquelCamo Member Posts: 91
    It will allow you to open your vent when it's raining and you can leave it open when towing.
    Mike and Lisa Campbell
    Springfield, MO
    Thanks for the insight!  Let the journey begin!
    @TallCamper just an FYI, before doing this you also need to consider your storage and any height limitations. I have clearance of 1.5” so installing one of these means no more shed storage. I’ve done just fine without one although I’m in the PNW. Enjoy your Tab and your new journey, and welcome to the Tab Family!
