Too much solar????
Don't know what to tell you PX? Maybe it's because you're out in the toolies and I'm on Charter cable direct? The link loads in 4 seconds for me here at my home.PXLated said:Mike - Hit the link, waited 2 minutes, no go - How long does one need to wait?Mike - Elmira, Mi / 2019 T@B 400 / 2021 Chevy Silverado LTZ0 -
Not currently in the toolies - got a good connection - doesn't make much sense unless I have to be a member and logged in over there.0
Not your connection PXLated as I get exactly the same behavior when I click the link. My guess is that this is either by design or a bug in the forum platform. My bet is on the latter as I can't come up with a good reason that you would need to be logged in, given that you don't have to be to read the post.Ben Trelease & Eleanor Bell - Seattle, WA - 2009 T@B Bell@luna TV Subaru Forester0
PXLated, did logging on to the LG forum allow you to use the links above?Verna, Columbus, IN
Verna - Nope, logged into both forums (different tabs) and it still just gets me to the home page, not the individual threads.0
The adventure begins. I now own 2x6 volt golf cart batteries. They are charging. I plan on the install Tuesday evening. I will add more solar inn phase 2 if needed. The new batteries should give us 4-5 days even without solar charging. More to follow.
Thanks again for all the suggestions!Norm & Pat. 320 S Outback Utah or somewhere else.
Cool, keep us posted - Am interested in updating my battery packs at some point.0
That's great, Norm. Please share pictures of how you position then in the tongue box.Verna, Columbus, IN
I will probably mount them outside the "normal" cover. I have a dual GC battery box and will probably mount it on the tongue farther forward. The reason is I am also installing a second propane tank in the old battery position. I will be removing the spare from the tongue and keeping it in the TV for now. Busy week ahead so I will post pics as I get work done. Our goal is to be able to be out away from the grid for 7 days with no worries. Then get a campground and do laundry etc for a day. Like everything in life though this too may change
GREAT, Norm! Where did you get the battery box, please?Verna, Columbus, IN
Thank you, Norm!
Your welcome Verna. Now you need a T@b to put it on.
Question: why two 6 volts? Why not just add another 12 volt?
Lisa and Tim
Cottonwood, Arizona
2015 Max S Sofitel--"The Hatbox" TV: 2013 Subaru Outback and 1994 Toyota Land Cruiser aka "the Betty"
More amperage. 2 6Volt batteries in series will give you 12 Volts at 220 Amp hours of current. It would take a giant 12 volt battery to do the same and cost a lot more. So far with phase one I am just over $300. spent.Norm & Pat. 320 S Outback Utah or somewhere else.
Norm
I'm impressed, double the propane and about triple the amp hrs!
I do have one question, did you happen to check your tounge weight prior to the upgrade and then after? That appears to be a lot of weight cantilevered even further out than stock.
Good job0 -
Prior I had the spare on the tongue as well as a second propane bottle. The spare and holder pretty much equalled the extra battery. So all in all I only added 10 lbs to what I had prior. I will weigh it today when I finish it. I expect 260lbs.Norm & Pat. 320 S Outback Utah or somewhere else.
Thanks, Normnormfun said:Prior I had the spare on the tongue as well as a second propane bottle. The spare and holder pretty much equalled the extra battery. So all in all I only added 10 lbs to what I had prior. I will weigh it today when I finish it. I expect 260lbs.
The reason I asked is because I came very close to making that same battery box upgrade, and still may.0 -
Did you make up the wires to connect them or was it a kit? Could you explain the wiring set up too, I am not that up on electrical things.0
The wiring was a surprise. The factory wire harness reached the box no problem. I did move the Zamp connector to the box, but that's easy. I was surprised at how easy this was.Norm & Pat. 320 S Outback Utah or somewhere else.
Rvfourseasons.com has several videos on YouTube that go into the why and how. In layman's terms.Scott, Orange Park, Florida...2012 Jeep Wrangler Unlimited Sahara... 2015 T@B S Maxx "Buttercup".1
Rad. The tongue weighed in at 255lbs. Both tanks full. That's 12.5% of the trailer weight. And only 5 lbs more than what I've been towing for 6 months. I'm happy with how it turned out. Now off to Yellowstone NP for the weekend.Norm & Pat. 320 S Outback Utah or somewhere else.
4 -
Great! Thanks for the update. Yellowstone, I have reservations for Yellowstone in mid Septembernormfun said:Rad. The tongue weighed in at 255lbs. Both tanks full. That's 12.5% of the trailer weight. And only 5 lbs more than what I've been towing for 6 months. I'm happy with how it turned out. Now off to Yellowstone NP for the weekend.0
