320 S Axle Width
Art
Member Posts: 5
Does anyone know the approximate width from the outside of each tie on a 2020-320S. We need to level a path to store it on.
Thanks Art
Thanks Art
2019 320S Sofitel - 2003 Ford Ranger Edge V6
Send an email to tech@nucamprv.com and Creed should know.Verna, Columbus, IN
@Art Or, The nüCamp website lists the overall width as 79” so 7-8 feet should allow you sufficient room-unless you back up like us so 10 feet might be better.John, Judi, Guinness & OD in PDX
T@Bit@t 2015 S Max Outback, ‘18 V6 4Runner -
74” on a 2017 CSS.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I measured our 2018 320S at 74" between the outside of the tires.-Brian in Chester, Virginia
Thank you all for your comments. We are preparing a level pad and using the 12’ x 12’ blocks filled with gravel. Only have 6 0f these blocks so want to get them under the wheels.
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
