PSA: Remember to Clean Your A/C Filter
I was doing odds and ends around the T@b, including some spring cleaning and pulled out the a/c filter to clean it. Given the set up, it isn't apparent how you do it, so, I thought I'd share the easy process for the S Maxx models. In less than a year, there was enough debris to clean that it made this a worthwhile exercise.
1. Remove the two square faced screws holding the trim around the a/c to remove the trim with a #1 size square screwdriver.
2. Pull the filter from the pull tab in the right side if the unit. The filter will need to bend due to the tight fit to the wall.
3. Clean the filter.
4. Replace the filter.
5. Replace the trim. Make sure the holes in the trim line up with the holes in the cabinet so that you don't unintentionally start new holes.
Thanks, Jenn. I believe there is a you tube video about this.2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
kybob said:Thanks, Jenn. I believe there is a you tube video about this.
Cool, can you share the link here, for posterity?2021 T@b 320 Boondock "Mattie Ross" | 2021 T@b Nights: 239 | Total nights in a T@b 455 | 2022 Jeep Grand Cherokee L Overland | T@b owner since 2014
I'll try and find it soon. I'm supposed to be working right now!2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
"T@B tips - remove ac filter"
Bottom line - simply pull the right side out. Warning- cleans itself when being pulled out so you may want to use vacuum before pulling or dust goes everywhere.Scott, Orange Park, Florida...2012 Jeep Wrangler Unlimited Sahara... 2015 T@B S Maxx "Buttercup". -
On this forum, look for the video link under the categories heading.2018 Outback S, Silver/Black - 2015 Silver Honda Pilot 4WD - Florence, KY
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
