We have a 2016 T@b Max. We camp primarily without hookups so we rely on battery and LP a lot.
We’re very grateful for the guidance of those who can explain things in simple terms, as neither of us is very technically adept! I learned a lot yesterday reading jkjenn’s early posts on batteries.
We had some battery problems this last week while camped on the shore of Lake Superior in our UP. I’m fairly certain the problems were due to the age of the battery and neglect of proper maintenance, so that’s an easy fix (time for a new battery and proper care!). On the plus side, the battery served us well for over three years, though it hasn’t gotten a lot of use since 2016.
In investigating the battery problem, I looked at the fuses on the converter closely and noticed that the amps of some of the fuses didn’t match the amps printed on the sticker that’s in there (see photo). We haven’t touched the fuses; this is how it came to us from manufacturer/dealer. Aren’t they supposed to match?
Also, is the SeeLevel II reliable for monitoring battery charge? I was persuaded by those talking about the monitors that plug into the 12v port, but didn’t see much info regarding the reliability of the SeeLevel II. Would a plug-in monitor be more accurate?
Thanks in advance for any info that folks are willing to share!
Dawn (& David)
The SeeLevel will tell you the current voltage of the battery AS IT SEES IT. The voltage could be the battery itself, the output of the converter if you’re plugged in, or the output of your car’s charging system if if you’re towing. I will say that the Victron solar controller that is connected directly connected to my battery generally reports a couple tenths of a volt higher than the SeeLevel.
When we are camping without hookups the SeeLevel voltage we watch for is 12.2. If we get to that point we charge the battery.
You may want to double check the power requirements in the installation manuals for your model of fridge & alde, then use a fuse that's only a few amps more, or check with NüCamp. Using a higher rated fuse than needed puts the appliance at higher risk.
Note on your sticker Fuse #2 Fridge is marked 10-Amps . . . well the NorCold draws between 11.6 and 13.6 Amps when on DC Power so the installed 15-Amp Fuse is required.
Adventures: 55 Nights: 376 Towing Miles 46,920
2016 T@B M@xQ
