Rear view camera helpful or critical when hooking T@B to TV?
I'm new here, about to get a new T@B Max Q. I am slowly getting my newbie accessories, and have been wondering how useful the rear view camera on your TV is in hooking up your T@B?
Thanks, Chris
I wouldn't add one to a vehicle, but I can tell you I love the one built into the latch on the tailgate of my Tacoma. I've always used magnetic poles (one on the hitch and one on the ball) and when one falls over, then I'm close enough to be able to hitch up.
And, welcome to the world of towing, and the world of camping in a T@B.
I have one on my f150. I can back up the truck and place the hitch ball directly under the hitch every time without fail on the first try. No skill required. I love jobs like that. Do you need it, no way, it just means ya practice a few times and get out and double check if you need to. Or.........travel with someone and they can be the spotter.0
Ditto to Verna! I can back up first try to within an inch on my own with our Tacoma...
J.D. & Sue
It's great for hitching up. Makes it look like I know what I'm doing! However, the Tab's so easy to move by hand, that the camera's not really necessary at all.
The camera is great without the trailer too though, especially squeezing into impossible parking spots in the city.Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya1 -
I have one on my Honda Pilot and line up the hitch like a pro every time. In my opinion it takes the stress out of hitching so is well worth it. It's also fantastic for parking in tight spots.Martin - Trailer name: James T@Berius Kirk0
My Jeep is the same width fender to fender as the T@B so lineing up is pretty easy, then I back up ever so slowly until the receiver taps the T@B hitch. Works like a champ. So, if your TV is like my Jeep, I wouldn't waste the money otherwise maybe. Or, I may just do like someone here in the forums does and put my iPhone back there and do a video chat with my iPad - instant backup camera.2
Yeah, I was pleasantly surprised to see that backing up the Wrangler and aligning it with the T@b was so easy.
I got one of these at Harbor Freight.
http://www.harborfreight.com/magnetic-trailer-alignment-kit-69778.html
Makes it very easy to back up to the trailer and much cheaper than a TV camera.
Patti - You can buy little telescoping magnetic poles that have tennis ball like tops - you put one on the TV hitch and the other on the T@B. You back up with the balls aligned (you can see them because the telescope up) and when they touch you're good to hitch up. Can get them at Walmart for probably $10.0
From what I have seen, the Camco version is a little sturdier than the HF version, though both are a little flimsey
With a little experience and seeing how your vehicle squares up with the T@B - Jenn & my Jeeps are pretty close to the same width - you may be able to ditch the balls.0
I cannot find the magnetic poles on Camping World's webpage. The ones I'm referring to are about 3' tall, are bright neon yellow with a red tip and magnets on the bottom. They work better with the larger tow vehicles such as SUV's and trucks with tailgates. They cost $22 at the store. I gave my brother my set because I don't need them with my built-in back-up camera on the Tacoma. They are extremely sturdy, made of fiberglass, and so much easier to see and use than the tennis ball magnetic telescopic poles that broke the first time I used them.Verna, Columbus, IN
But the concept's the same with either the cheapie or the fiberglass versions and a lot cheaper than a backup camera.1
Just found this very helpful post, as I have been experimenting with a backup camera. I didn't want to spend the $$ to enable/install on the Wrangler's GPS, so I bought a wireless license plate one on impulse. It's not going to work because of the location of the Jeep's license plate, spare tire, etc.
I have learned how to align the Jeep's brake light to the T@B logo, but haven't quite figured out the distance.
I like the idea of these magnetic poles. Here are the Camco ones on Amazon.
http://www.amazon.com/gp/product/B007772HG4/ref=pd_lpo_sbs_dp_ss_1?pf_rd_p=1944687742&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B001F4MQYI&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0RJQMNK5A4STJV711V61
Beth
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx
2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual0 -
Beth, I think the Wrangler Unlimited is quite easy to back up to the trailer due to them being the same width as the T@b. I had those magnetic rods, and they did work well, until they broke. I didn't replace them and am now getting much better at backing up to hitch more quickly. I love that with a T@b, you just have to be close.
I find the Wrangler is almost the exact same width as the T@B so is easy to center. For distance, I jack the T@B hitch high enough to clear the ball on the Jeep and then ever so slowly back up until the Jeep hitch taps the T@B hitch. At that point you can easily jiggle the hitch onto the ball as you're no more than an inch off.1
Thanks! Maybe I'll just forego the magnets and do more maneuvering practice.
Beth
Minnesota
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
