Another SeeLevel question & a blooper
lkc001
Member Posts: 877
Another trip out last weekend and had a great time! Trailer towed excellent and only one small minor mishap which was totally my fault and a "duh" moment. I forgot to raise the crank up high enough & forgot to take the wheel off--made it about 50 yards & said "something's wrong!" Had to back the rear tires of the truck onto a couple of legos to get the wheel off--Luckily didn't bend the jack post and only scraped up the wheel a little more- - - - I got in a hurry --duh
So anyway--The fresh water tank never came down from 100% and the grey level never came above 0%. We were using water did have grey water come flowing out at the dump station. The SeeLevel for the black tank and battery seemed to work OK. I guess it's better to have a more accurate gauge on the black tank than the fresh & grey water, but they seemed to at least register something last trip?? I was almost dead on level. Last trip the fresh & grey water levels were significantly off but at least they worked. Now I can't tell if my fresh water tank drained completely. I did open the fresh tank valve and left it open on the 2 &1/2 hour drive back home.
Any thoughts?
Any thoughts?
2018 Tab 400
When you get home, lower the tongue and open your fresh water drain valve just to confirm that you are empty.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
@Sharon_is_SAM will do. I wish there was an easy way to actually see the tank levels. . . .2018 Tab 400
2016 Nissan Frontier SV 4x4 Crew Cab -
Anyone else had an issue with just some of their Seelevel sensors?2018 Tab 400
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
