Just purchasing a new 2020 T@B and plan on towering it with a 4 cylinder Porsche Macan Sport. It is rated to tow 4800lbs with brake assist but I am wondering if anyone is using this type of car. I don’t want to be crawling up the hills at 20mph as we live the pacific north west and will have mountains to deal with. Anyone pulling with anything this small?
Kr@cken
2020 T@B 320 Boondock
2020 Subaru Ascent
Bainbridge Island, Wa
0 ·
How fast do you want to go? 😄
T@B speed trial
2020 Subaru Ascent
Bottom line factory says it can tow so you could try it then decide.
Some real-world concerns/questions might be:
+ Macan was not designed for towing as it's primary use
+ Macan does not have Trailer Sway Control System (vehicle software to control brakes and engine
when trailer sway is detected). Should consider a basic Sway Bar addition to the T@B tongue.
+ Does the Macan have a transmission cooler?
+ Macan does have a dual-clutch transmission - - - know they have big $$ 40K mile service needs - - -
any web data on dual-clutch towing (maybe VW installed dual-clutch)
+ Are you planning a few weekends a year to be out with the T@B or ??? The more miles you do the
more likely you'll be happier with a Towing Designed vehicle.
+ Macan sales ads note 4,400# tow rating then show one towing a jetski - - - bit different from
weight and frontal area of a T@B.
And get a wireless brake controller to save fouling up the nice interior too much.
So I would guess you'll want to slow to 35-45mph on the steepest passes, but otherwise should be okay. Definitely get a brake controller though, and perhaps a way to keep an eye on transmission temperature. That and change drive train fluids more frequently.
I would definitely do some research, and check vehicle specific forums.
On paper, it looks like you should be fine though.
https://www.macanforum.com/forum/engine-technical-discussion/111289-towing-travel-trailer-macan.html
Springfield, MO
2020 Subaru Ascent
2020 Audi SQ5
