Please Check Accuracy of My Wiring Diagram for BMV-700 Battery Monitor
[Deleted User]
Hi there, I've been getting help from Sharon, so hopefully she will find me on this new post. I thought I would create a new post since others might want to chime in. Can someone please verify that my diagram is correct as drawn to install a Victron BMV-700 in my T@B 400? I don't have the phone wire drawn in the photo.
Thanks!
@TabbyShack, You need someone with a 400 and a shunt to confirm your plan. I can see that the red wire with the fuse is the battery positive, but I think the white wire in the loom comes off the battery negative and that should go to the shunt. I am not sure what the very large wires go to, although I can guess they are for solar and the inverter.
Ok, got it installed based on my drawing and nothing blew up or stopped working so my drawing is correct!
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
