We just bought a new F150 (new to us, 2016) and I'm wondering if we'll need to change anything with the hitch. We're going from a Toyota Highlander. Will we need to get some kind of adapter? Newbies, still learning...
We have a F-150 for our TV also. I generally want the trailer to tow in the level position. I figure there is less drag. I do have an adjustable ball which allows for quite a range of up/down.
We have a 2016 F-150 crew cab 4x4 with FX4 and max towing package. When I hook up our T@B 400 empty, which has a 400# tongue weight, it squats the back of the truck 1 1/4” inches. I have a B&W adjustable hitch, so in its highest ball position with the adjustment pointing down, the trailer is just about level. I was a bit surprised how much the truck squatted with just the empty trailer. We will see how it behaves with a loaded trailer next weekend.
We tow with an F150 of similar specs as well. It will drop a little given the tongue weight but you should be fine assuming you have adjusted the hitch drop so the trailer rides level.
Mine is a 2014 and I get similar with a T@B 320. It's likely the loaded trailer won't really make any difference unless your loading up the front of it with bricks or gold bars.
Put a load of wood in the bed and it'll really squat.
Mike and Lisa Campbell Springfield, MO 2016 T@B Max S - Sold March 2020
Springfield, MO
