T@B 320 CS, the yellow do-hickey. It can be pulled forward (180 degrees) or can stand up (90 degrees). Correct me if I am wrong but it appears to be connected to the cold water feeding the Alde hot water tank - correct? The manual has no mention of what it is or what it does.
Thanks, Jerry
0 ·
Adventures: 58 Nights: 405 Towing Miles 50,180
Thanks, Jerry
Later today I will be receiving a my water pressure regulator so that I can hook up to city water and see if that helps with filling the alde tank.
Thanks, Jerry
Make sure the pump filter is clean and screwed on tightly. Make sure all connections serving the pump are tight to prevent air from entering. You can always unscrew the inlet pump tubing (by G) and see if it will pick up water when submerged in a bowl/bucket/glass of water.
2020 320S Boondock Lite (silver w/blue)
2019 Subaru Ascent Premium
It can also be a sign of a leak somewhere downstream that prevents it from reaching the full pressure needed to turn itself off.
Thanks, Jerry
Thanks, Jerry
Thanks, Jerry
I = black hose is part of the Alde glycol flow assembly and attaches to the auto air-bleed valve (bleeds air from the glycol). The clear hose attaches at the top of the Alde and allows air to enter the water tank to prevent a vacuum when draining the tank.
Thanks, Jerry
Thanks, Jerry
