Alde Leak Normal?
With the Alde water heater full and the trailer raised all the way up on the tongue, water (not glycol) leaks from the rear bottom of the Alde unit.  This happens in reverse when I lower the tongue all the way down- water will leak from the bottom front of the Alde unit.  Is this normal because of the extreme angles?
    I would ask Spencer from Alde.  There was someone not too long ago on the forum that had a water leak.  Water collected in the pan under the Alde.
  • mona
    mona Member Posts: 246
    edited September 2019
    Never had that happen. Doesn’t sound normal. Have you checked the Alde compartment for leaking hoses or connections?
    Jeannie
    2015 T@b S Max  white with silver trim. 2018 GC Trailhawk.
  • Tabaz
    Tabaz Member Posts: 2,420
    Thanks SiS - looks like the water is coming from the drip pan, just not out that little hole near the exhaust.  I'll call Alde first thing tomorrow.
    @Tabaz , yeah, as much as the whole condensation idea sounded right, it may be a leak.  Good luck!
  • 4ncar
    4ncar Member Posts: 1,072
    Condensate was my knee jerk thought...but alas, something else...?
  • Tabaz
    Turns out the leak was just water that had accumulated in the drip pan.  Have been testing it for several days and no more dripping front or back with the trailer in extreme angles.  Whew!
