A/C drain? 2019 320 U model. Should I see water?
ColleenD2
Member Posts: 583
Hi,We have a 2019 320 U so our a/c is on the floor. I see people talk about having it “level to drain” but does drain mean I should see water in the ground outside of the T@B? It just looks like a apartment window unit to me. We are always level but I have no recollection of seeing water under there.
Thanks in advance for your help.
Colleen
It really depends on the humidity level. High humidity you should see water. Low humidity very little maybe none.
- Hash T@B Fun
@ColleenD2, where is the drain located for your A/C? Is it a Cool Cat?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
It is recommended by others on this board to have the front end lower than center to allow the water to drain
i have a Q model with floor ac unit
I did not have the front lowered and it did not drain so when I raised the trailer to put it on the car water ran from the pan into the trailer
Lesson learned, I will lower the front end -
It’s not a cool cat, it’s just a regular Friedrich window unit looking thing. The drain hole is under it but there is no water coming out. I don’t see it draining anywhere else so maybe we have a humidity balance. I don’t have a full pic of it but you can see it a bit more here.
We've slept in 34 states, 2 countries & counting -
Looks a lot like this. https://www.friedrich.com/consumer/products/chill2019 Custom T@B 320 U Boondock Lite-ish
Well, the wall mounted A/C drip pan drain hole is in the corner closest to the Alde display, so slight tongue down does the trick. I think nuCamp tech should be able to answer the question of where the drain is located for the U model. Tell them it is the Friedrich so they don’t think it is a Cool Cat. The Cool Cats in the 400 just drain out the side grill.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Thanks.2019 Custom T@B 320 U Boondock Lite-ish
- 920 Introductions
- 75 Teardrop Groups & Links
- 915 Tips & Tricks
