cool cat heat pump
Tundra57
Member Posts: 640
I tried the heat pump function of my cool cat ac. Worked awesome. Now ac works but heat pump doesn't. I assume I set something wrong. I set the screen for heating to 75 and leave it on that screen. It definitely is not 75 in the Tab. The cooling temp in the AC cooling screen is set to 60. I'm going to try setting that higher than 75 in case the logic of the controller is confused (like me most of the time). Any other ideas?
I have not tried the heat pump of the Cool Cat as I know the propane, or electric, heating of the Alde is marvelous. The Alde just envelopes you with the heat without the noise of a fan.
You might try the higher temp temp on the Cool Cat setting as I set the Alde at 41* in the warm summer temps, as that is the lowest the temp will go. Try the higher temp setting, but realize I have no actual experience with heating with a Cool Cat.Verna, Columbus, IN
I'm a dummy. Even on top toe and I'm 5'10 the screen is hard to see. I set the cooling temp to 80 then in the furnace screen I set the temp to 74 then pressed the mode button again. The screen still looked the same but now it worked. I really have to either lower that controller or tilt it so I can actually see it. Small problem lol.
I want to come up with exact dimensions for a wedge for the Cool Cat display..... give me some time here...sick sister, trying to create a marvelous cherry desk for a friend, create drawers for the new F-150, and driving to nüCamp for delayed warranty work. I’ll get back to you on this.....Verna, Columbus, IN
I'm going to play around this weekend to see if it is doable. I'll let you know how it goes.
There are two heat settings on the Dometic thermostat. One is for the furnace, which is not used and won’t do anything if you select it. The other is for the heat pump. Make sure you are selecting the correct heat setting.Tundra57 said:I tried the heat pump function of my cool cat ac. Worked awesome. Now ac works but heat pump doesn't. I assume I set something wrong. I set the screen for heating to 75 and leave it on that screen. It definitely is not 75 in the Tab. The cooling temp in the AC cooling screen is set to 60. I'm going to try setting that higher than 75 in case the logic of the controller is confused (like me most of the time). Any other ideas?2019 T@B 400 Boondock Lite
2019 Chevy Colorado Z71 Duramax0 -
Yes you are correct I was in the wrong screen but I couldn't see it on tippy toes. :-)
I tilted the Dometic thermostat by removing the cover and backing out both screws that hold it in place. I cut a short piece of 3/8 x 3/8 inch stock just long enough to fit under the top of the thermostat, side to side. I got a longer upper screw and re tightened both screws. Replaced the thermostat cover and off we go. Kinda a redneck solution, but it works. It pitches the thermostat just enough to make it more visable. Does not seem to change the operation. May actually let a better air flow to the thermostat.
2018 T@B 400, 2017 Nissan Titan Crew cab1 -
I made this wedge and it helps my Dw see the Coolcat display.
2013 Tundra TRD 5.7L
Massachusetts0 -
So for a quick and dirty fix, just point a led flashlight at it. You see it in grey and black and it works in a much wider angle. Acts as the backlight.
